In this post I hinted as to what my next project would be. It is a Don Srull 2 times enlargement of a Comet 32” Sparky. This is roughly based on Ed Lidgard's 41 Sparky. The impetus for me to build one of these was the great time I’m having flying the Old timer RC Benny Boxcarr.This model will be built based on my recollection of the SAM speed 400 old timer Texaco event. This will be using tech I’ve forgotten for over 2 decades. It will be 6:1 brushed 6V speed 400 on 7.4 volt 2 cell lipo. I’ll have to remember how to seat brushes, time for spark-less commutation. And learn how to climb on the wing.
I will be changing the structure to meet my desired performance and still look like a Comet Sparky. First I’ve changed the spars from a dual blade type to a squiggly web I beam type (loosely based on the Boeing sine wave spar). Next I did away with the fish mouth Leading Edge (LE) we see far too often with balsa ribs. This guarantees that the diamond will split the rib at the slightest tap! It also means the the wing will follow any warp/stresses in the LE. I’ve also changed the LE to a double laminated one. This should add stability to the LE as the forces in the wood might counter act each other, minimizing long term warping. And to save weight, and that I like them, I’m using a 5 layered 1/16 laminated tip hoops The lamination allow me to make a stepped splice with the laminated LE.
I’m also trying to raise the wing tip to aid in aerodynamic efficiency. This gave me the option to try to sand in some wash out to the tip.
BTW; All the balsa wood came from Aloft. While not contest grade it is good, dare I say great, sport class wood. Far too often the wood we see from places like Midwest look to be a close kin to Oak!
