jvaliensi
Active User
Hi,
I like to use a sensor w/ telemetry for current, volts and consumed MAH in my electric airplanes. I like to determine how long to fly based on MAH used, not on time or voltage.
I use Jeti system and one their MUI sensors with great success. Then I learned about the UniSens-E, which is much more elegant in design. So, I bought one. I wired per instructions without the RPM sensor.
When I went to complete the circuit by plugging the sensor to the battery there was many sparks, like a short. Part of the bass connectors were melted. I've wrote Stephan (the manufacturer) and he is basically baffled. He told me that if it was a short the little negative lead would melt 1st and that was not my case. I pulled the sensor out and checked between positive and negative leads with my multi-meter and found no short. The sensor was not physically damaged other than the connector.
The leads from the battery were separated by at least two inches, I don't see how there could have been a short.
Anyone out have any ideas?
