Slow Stick
  • Thread starter Thread starter hatman
  • Start date Start date
I’m currently using this eflite Park480 with a 10x3.8 prop. It takes a small plywood plate to adapt the hole patterns. Half throttle and it pokes along. Full throttle gives vertical performance. The Park400 works about the same. Very quiet either one. I typically use a 3s battery but it runs on a 2s as well.
Edit: they will also fly on a 2206 2500kv with a range of prop diameters. I’ve used a 3 blade 5x5. It’s kind of strange to see a slow flyer with a high speed prop.
I think this plane teamed up with the FrSky X9 Lite transmitter will be a nice combo for someone new to the hobby. :)
Adding the TX will move Aloft into the market place now held by Horizon with their bind and fly stuff.
Other than charging the battery and actually mounting the radio stuff these are getting close to a true charge and fly package, particularly if you offer an OpenTx templet for the X9 Lite.
We expect our container in a little over a week. Then we get to see how long before it makes it through customs. I expect to start selling them before the month is up if customs behaves.
Well, they are due into the port on Monday but seems we won the random raffle and get the intensive inspection prize. Basically they randomly select some shipments to take a very close look at. This adds more paperwork and more expense. Joy joy. This is the first time we have won this fine prize. Should sail through, but never know how long before they get the inspection going.
Stuck in customs for 2 weeks now. :( Waiting for customs to inspect it.. Should take them all of 10 minutes to open the door and give their blessing, but been setting for 2 weeks now waiting for them. Good news though... I get to pay storage while waiting. ?
Got the back in stock notification. Thats a great price.
Did you really want the page to read
“Yes! We have the last of the...”?
Need to update the page, but yeah, they are here! Look really good, still loading them into the warehouse.
Had to be on the hottest day this summer? Uggh.. We are beat.. We have a few kits in stock. :)
On the plus side we also have a new photo studio at the shop, new walls to control the lighting. :)
Thought I would show the new motor/ESC/battery mount that we will be offering for the Slow Sticks. We have been using the same basic design on the Mini Slow Stick with great results. Just a simple and clean setup that makes it easy to use a wide range of motors.
This plane is setup for one of our employees that is learning to fly. The little Emax motor keeps the plane light as does the small battery. Being a small pancake motor it would be a pain to mount with the stock motor mount, so this little tray makes it easy to use a very wide variety of motors.
Will see how robust it is after a day of training. :) Personally I really like to keep these planes as light as possible, and that starts and ends with light motors and light batteries.
We will be using some 3S 850 and 1050 packs as we had some sitting around in the shop. This with a GWS SF 8x6 prop seems to do just fine. Will try and capture a little video of the training. :)
PLA - We have been doing motor mounts like this for a while now with PLA with great results. I will warn you that if you run a motor HOT, then you should not use a plastic motor mount.
I am happy to report that the plane pictured above flew great with just the right amount of power for flight training. Enough power to get around, but not so much as to get into constant trouble. Best of all, the plane weighed very little and flew a long time on a small battery. A very good mix for training.
Happy to report that Victor did great with his training and the plane is still like new, no carnage. The poor guy had to deal with 3 different flight instructors, but I guess he will be well rounded. LOL
Beacon Quick Grip
I used Quick Grip on the leading and trailing edges of my wing with no problems. So I decided it use it for the plastic wing jointer. As can be seen in the photo it really ate into the foam. The only reason I can think of that might have caused this is lack of ventilation under the plastic. Anyone have another explanation?
It is NOT a foam safe glue. It is an acetate type glue and will eat styrene foam! This has nothing to do with ventilation.
Hexane and Acetone eat (dissolve) styrene foam
Take a look with a magnifying glass. I think you will find that the beads (under the paint) in contact with the glue have started to dissolve. It not, then the paint offered enough protection against the glue's solvents until they had off gassed. The bond I'm sure is very poor.
