RadicalRC.com still shows as of May 10, 2019 the straight aluminum tubes which you can bend.
Below is copied from their website:
Slow Stick Aluminum Straight Wing Tube Set
Aluminum tubes required to build a straight wing, no dihedral Slow Stick Wing set up. Easily Bent to your chosen Dihedral. Note the pre-bent GWS 12-degree tubes are discontinued. Good precision fit to factory 3mm spars and a little longer than factory part at 3" to reduce spar wobble inside of tube.
SKU Number: RRCSSWTS
Price: $2.00
Sorry, I have not heard a hard commitment on when it will all be pulled together. Since the plane has not been produced for 5 years it is all taking a bit longer than originally thought.
Wayne,
When these come in, will you (Aloft) have an addendum for these listing "Modern Equipment" . Back in the day one of the beauties of GWS was that they offered all the stuff needed to fly these, and fly well!
(Brushes, round cells, anolog servos, ESC and 72 mHz rx)
I think Aloft is well positioned to do much the same thing!
Yeah, we already outfit these with the brushless motor mounts. Just need to get a good inventory of motors and ESCs for these, then just a couple of 9 gram servos and a receiver and the new owner is ready to go.. I suspect many people will already have a little 400 class brushless or smaller kicking around. These planes will work with a huge variety of gear folks have sitting around, but yes, we do want to be able to offer full setups for new folks. They are afterall a good little trainer.
I think this plane teamed up with the FrSky X9 Lite transmitter will be a nice combo for someone new to the hobby.
