Not yet. Need to take a look at the dates people said would and would not work and pick one.
I would be keen to join up with 1-2 of the experienced flyers for some practice sessions, if anyone is willing. Apart from work travel 1-2 times a month, I can generally make time on Thursdays, Saturdays, and Sundays. I usually fly in the mornings (7am or so) but I undertand the winds pick up in the afternoons, so I'm planning on that.
Let me know if you want to head out to a local slope. I'm in South Bay so I don't need a ton of notice, can wait and see how the winds are doing (even up until the day of). I also have plenty of planes, don't need to wait for the Slingshots since this is just practice and orientation.
If someone wants to fly on a day other than Thur/Sat/Sun I can try for that, but I'll need to plan in advance.
Thanks!
@RafaelAvila If there are pilots who wish to race but didn't get their orders to you in time, you could re-allocate 2 of mine to those individuals so they can join the first race. I can then take delivery of my other two planes after the initial race. Would not want anyone to miss out if it can be avoided.
Maybe I missed it. Can you put a link here to where we pay?
Here you go:
3 or 5 servos. If running 3, you will tape up the flaps. (ailerons are top hinged and flaps are bottom hinged)
Someone is asking what all they can modify the model. He is thinking of adding a thin layer of fiberglass to make her more durable.
Lets keep it simple, we don't need to be bending any rules, this is for fun. If the other pilots see something they don't think is within the good nature of the racing, they will call you out for it and call your MOM to complain. If you tweak something, I'd hope you share with the others what you are doing so they can do the same if they like. Maybe it will further the qualities of the planes we are flying. Thats cool.
I won't be flying in the event but I completely agree with Wayne's sentiment on this
I've been in a lot of events that started out as being equal tests of piloting skills, and then the arms race ruins them. I'll tweak this, nobody is going to check for that... eventually the "fun" class folds.
At least hold one or two events with everything the same, then propose "improvements" if needed. But fly first. Again just my 2/5th of a nickle from the peanut gallery.
Hey, I ordered one plane and servos a few days ago. Please update. Real name is David, order number
AH-74133​
Also, I ordered three servos. Perhaps I'll order two more and a receiver and choose pickup, and then have you add it to my original order. Would that work?
@RafaelAvila Can you help folks with a little shopping list? (Might be a great use of our new shopping cart script.)
Yes, we can combine multiple orders, just leave a note to ship the new one with the plane order. We have not shipped any out yet, the guys were cutting carbon this afternoon for them. Yes, you are all welcome to stop by and pick your orders up in person if that is easy for you.
Sorry guys, we have all been swamped this week keeping all of the wheels turning. :)
Ok, here is the shopping list for anyone who needs it.
This model uses 5 servos because we added flaps, which help a lot during landing. However, if you're better at landing than I am, you can save a little money by not using flaps and simply gluing them to the wing.
We currently have 4 servo options that can be used:
1st (my recommendation): ORBIT servo – available at this link.
or
EMAX ES3301 – available at this link.
EMAX ES3302 – available at this link.
First, you will need E6000 glue – available at this link.
You will use this glue to make the hinges for all moving surfaces, including the ailerons, flaps, and elevator.
You will also need CA glue. I personally use BSI-106 Medium CA – available at this link.
to glue all the cut parts together, join the wings, and assemble other sections of the model, including gluing the carbon fiber spar inside the wing.
For my setup, I use a 2S 450mAh battery with a JST connector – available at this link.
along with a voltage regulator to bring the voltage down to the range the servos use (between 5V and 6V). – available at this link.
However, you can also use a 1S Dualsky 600mAh battery. – available at this link.
Oh, and you will also need some lead weight (or something similar) to place in the nose of the model in order to achieve the correct CG (Center of Gravity).
lead – available at this link.
Stick On Steel Weights – available at this link.
Don’t worry — I will make a build log on another page here so everyone can follow along with the assembly process. Everything is actually very simple to build.
Also, to make it easier, here is the shopping cart. Just open it, remove anything you don’t need, and you're good to go.
Do you think a 2s 800mah Life pack like this would work or too heavy?
Sorry, I tried this one, but it seems to be too tall, so the canopy won’t fit.
or
Would a glue like this work for the hinges?
Uhu Por
