It pains me to admit this in front of everyone, but I damaged my little 60" moldie racer. The good news is I don't think I damaged the main spar. You can see that the wing skins are showing damage. At the flap hinge line both the upper and lower skins are showing tension damage. A head of the spar the lower skin is showing a substantial compression wrinkle. These lead me to think that there was a lot of forward motion of the wing tip as the plane came to a sudden stop! And that this resulted in relative motion around the spar.
The tension failures look easy enough to repair. Saturate the tear with thin CA. then sand the surface to remove any paint trying not to disturb the glass fibers. The removal of the epoxy paint allows for the introduction of 0.5 oz cloth to be laminated over the tear. Sand with a hard sanding block and feather edge as one would prior to paint.
Now the compression damage is a bit more involved. I first drilled a hole in the LE to allow me to use a 0.027" music wire to lift up the skin to be co-planer with the original skin. This meant I had to put the wing under stress (tension) to unload the skin. Once the compression valley was 90% removed with the wire I drilled a CA vent hole where the wire had penetrated into the rohacell foam. I removed the wire and poured thin CA into the channel made by the 0.027" wire to harden the damaged rohacell foam trying to give the skin some support from inside. Again sanded away the epoxy paint and did a lay up of two layer of 0.5 oz cloth, to gain some fiber strength in the skin over the failed area. Feather edge the glass and epoxy, paint to match.
If any of you guys have a better way please let me know.
