Ok, what you show in the retaining wall is an elegant way to add a buttress to a wall. It is not a web dealing with shear loads. Its only application here is that it might help in the wet assembly of the wing, as sine wave web would stand proud a lot easier than a straight web.
Tubes work well to transfer torque. The issue with them is how to introduce the torque into the tube. Often this is done with splines.
Not sure I follow your questioning of putting webs inside a tube. You might want to look into the tubes used in heat exchangers (boiler). Often times these have internal walls (fins).
As a load beam the tube is horrible as a function of mass. This is because most of the mass is not orientated properly. If one remembers that a beam responds as a function of distance in its load bearing members, most of the mass in a tube is not at the top and bottom. This is why webs in the load beams are a lot thinner than the caps. (The only reason we see tubes in some ARF gliders is convenience. Most need at least two beams for any hope of working, or are very thick walled).
As to the failure mode of the sine wave spar it will be in the "I" beam BB section if the beam is subjected to torsional over load. It will be in the at the "C" beam (AA-CC section) in bending moment. Rarely are the loads purely one type or the other. The sine wave beam can address both and as a result is a stronger structure for any given mass. You are correct that each section of the beam will respond differently to different loads.
If one is constrained by needing to use a single load bearing element to address both bending and torsional loads there is little to can out perform the sine wave beam.
This sine wave beam has a huge cost as it is difficult for a mill to produce such a structure. The "I" beam is used mainly because it is easy to make and can handle bending loads. But when needing to address dynamic load that have a rotational component they as horrible. (I like looking at structures that have failed in hurricanes. I often think how these might have survived had they used a sine wave beam rather than a "I" beam.
In the composite sine wave beam the weak point is as Doc. mentions the spar cap adhesion. The Boeing patent is trying to address this limitation. With the stability that the green section of web provides, this bonded weak point is greatly enhanced. This is why the Aeroic HSWS still offer a substantial improvement over the classic I beam and box spar wings, used by other glider builders, even when both OEMs are using the same dry modular construction methods.
Not sure I made it clear, tubes are horrable as load beams, for any given mass.
