As stated the larger arms are more tolerant of wear.None of the European manufacturers of the very fast, very heavy and very aerobatic Swifts and the like either use or even recommend IDS type control surface linkages. Also maybe have a think about why Spencer L. and co don’t use IDS.
Going 500 mph is a different application than what normal human beings fly in the hobby. LOLNone of the European manufacturers of the very fast, very heavy and very aerobatic Swifts and the like either use or even recommend IDS type control surface linkages. Also maybe have a think about why Spencer L. and co don’t use IDS.
Good points John - thanks.Some are artists with dremel tools (me, not so much)
My vote , not installed.
The builder then has a choice, IDS, top drive, bottom drive, DS style, Tomas Liu drive, brass control horns, whatever the model and flight envelope calls for.
Hi Wayne - Typo: Your internet Vassal got Pierre's name wrong. Rondel, not Rondell.What I would love to see if a fully installed IDS spoon in a fully moulded wing.
This is exactly what we did with the new Quantum F3X gliders.
Quantum 2 DP Electric Glider - W/ IDS installed
3 Meters of Electric Fun! Here's what the manufacturer has to say about their plane design. The Quantum 2 DP electro model uses the same support surfaces and V-tail as the Quantum F3F/ F3B version. Although the fuselage is designed to be very slim, it can easily hold up to 4S Lipo. The diameter...alofthobbies.com
Quantum 2 DP F3F/F3B with IDS installed
The Quantum 2 DP was created in collaboration with Dirk Pflug and Pierre Rondell. According to Dirk, the objective was not to replace the original Quantum, but to set slightly different priorities: Thus, the glide ratio with neutral flap was improved in the speed range of 20-40 m/sec, which is...alofthobbies.com
Actually we did more. The entire plane is setup for the servos, just drop them into the trays. Yes, this costs more to have done.
My ambition is to try to do 'drop in' models like this, but not now.What I would love to see if a fully installed IDS spoon in a fully moulded wing.
I think that is a very wise statement, Wayne. Oh so true.Oh, who knows. Pilot is probably the more important part of that equation.
Whatever happens the horns and instructions on how to fit them will be there Ty.Pre-installed control horns is ideal since I'm not likely to go the ids route. But not crucial at all.
If not pre-installed, please supply the horns in the kit. The more linkage gear that can be included the better.
Jerry are you using IDS?Gentlemen,
I am having issues transitioning between 'normal' (Jets & 40%) aircraft & gliders with 'very short' control horns. Compounding this is the extreme movement of the flaps. I am concerned with using >90% of the available servo travel.
This is the last step I have to complete the build. I have graphed out the surface movement relating to servo movement prior to installing the control arms. The first measurement is the hinge line to the hole. Next is servo arm length trying to keep the arm either inside or outside the wing skin trying to avoid cutting the skin.
I am dealing with bottom-hinged composite surfaces. The 2 kits I am dealing with do not have even a minimal instruction manual discussing this subject.
Does anybody have any thoughts?
