setting up vtail sweet vee rudder elevator problems
sterk03
I am using a NX10 spektrum transmitter to set up the 2 servos for v tail glider. I had it working last night but now this morning it went back to the original problem somehow.. I have the 2 servos in 3,4 elevator and rudder.
I selected V tail B in setup options, maybe it should be A but had it working fine in B. So I got the elevators working fine with the right elevator stick and I mixed the aireron to Rudder to put the control to the right stick. Right now the stick is moving the ruders in reverse. I cant just swicth it as aileron only has one switch and it then makes the rudder switch the elevator???? the elevators has 2 reverse switches but I need the rudder reversed. I am think it has to do with challel asign as I dont see any revers switches for the rudders yet i got it working perfectly last night but now cant fly as rudders have changed. I tried the one servo to ailerons but that did not change anything...maybe do to my mix? Any help to a newby would be great. thanks
Sterk03
Ok right or wrong I went back to setup and added wing with two ailerons/rudders and changed the V tail to A instead of B. Now everything is working fine.which one did it I do not know but I will save the settings and it should hold this time, I hope. Thanks but still open to suggestions and maybe the correct way for setup.
Sterk03
Now it wants to snap in entering a turn with the vtail??? I know there is a way to keep the up elevtor/rudder normal setting but I believe you reduce the down elevator to a lesser of angle so it turns more like a rudder and not snap rollong with the ailerons? Any info is appreciated?
