Sessanta tail servos?
Asat
I know the recommendation is 8mm servos but I just got my Sessanta and the Frsky 5651 I bought for the tail do not fit in the tail opening, they are too thick and will go in at the fwd edge of the opening but you can’t move them aft. Do I grind off some carbon of the fuse back there or get thinner servos? Plus there’s no way to get two servos back there unless one is mounted fwd never to be seen again - is that the design intent? Any help appreciated….
Never mind, it looks like that is the intention- one servo goes fwd and is inaccessible and the other is on an angle with the horn hanging out…
Yeah, pretty much, it is not the most fun, but take your time and it does work well in the end.
You can place the rudder servo forward in the fuselage and use a pushrod to drive the rudder. Just depends on how you would like to lay things out.
