I am having some chattering on some of my servos both analog and digital servo. Is anyone else having this problem? It does not seem to be a problem when I fly. Am I doing something wrong in my set ups? You guys have been verry helpful in the past, for that I Thank You all.
What servos are you running? High end servos will hunt for center constantly, leading to some chattering. If you are running older servos, there's a chance the telemetry output is disturbing the signal. Alternatively you may have your ADC filter off, this is set on usually but if you fly quads it should be turned off.
Thank You, I will look into that, I am still new to the Fr Sky radio and not sure what the ADC filter is or where it is located, I guess it is in the receiver set up.
Normally digital servos buzz rather than chatter. Try to either reduce or turn off telemetry and see if that fixes the problem. If you use long servo extensions, are they braided? Braiding reduces the ability of extensions to act as antennas
