Last night I was helping a forum members program his X9D+ for a 6 servo glider. I noticed that when the glider was assembled that there was a lot of distortion on the wing skin and movement of the wing servo.
This was traced to the servo mounting trays. With today's real narrow servos the servo arm spline boss is often very close in diameter to the servo’s body thickness. This means that it is very easy for the servo output arm’s spline boss to to hit (rest) against the servo tray before the lugs of the servo and tray make contact. If not corrected this will distort the servo tray prior to being glued into the wing. This will cause all sorts of havoc with skin distortion and servo motion. I will try to make a drawing showing this concern.
In the mean time make sure that there is nothing from the cut off arms than can hit the servo tray prior to mounting (glueing in) the servo trays. All the servo mounting pads should be making contact with the servo trays mounting pads and not distorting the tray prior to being glued into the wing.
