thenated0g
Moderator
I picked up a Sequoia 2m from @Wayne and will be documenting the build process here.
From the store listing:
Sequoia 2 Meter
This is the sort of plane we dream about at Aloft. We love finding well thought out and well made gliders. We stumbled across these and had to bring them in. When they arrived it was like Xmas. I have been flying slope gliders for many decades and you know a well refined design when you see it...
| AIRFOIL | HN 785 7% |
| WINGSPAN | 2 Meter |
| EMPTY WEIGHT | about 850g, 30 ounces |
| RTF WEIGHT | from 1130g, 40 ounces |
| CONTROLS | Aileron, Elevator, Flaps, Rudder |
| CONSTRUCTION | Foam / Wood Wing, Carbon Reinforced, Fiberglass Fuselage |
| FUSELAGE LENGTH | 1150mm |
I have read thru a ton of similar builds on rcgroups, but this will be my first "kit" build. I plan to keep it stock with the exception of adding a ballast tube in the fuselage under the wing joiner tube. Probably a carbon tube as i have those on hand.
From the product description it appears that the wood is finished already.
Here are the electronics going in:
6x Corona DS843MG servos
Double Wall Pushrods for tail controls
Frsky RX8R Pro RX
6v 1300mah nimh battery
and ill try and stuff in a vifly finder 2 lost model alarm.
