Doc J
This assuming I can repair the wing to some form of functionality. The adhesive used to bond the skins to the core has proven to not stand the test of time. I've found two other areas of delamination. Although small it is an indication that the wings are not durable and may not be suitable for flight.
And as mentioned the fuselage isn't worth the effort to re-wing. So while I'm willing to try to build the model as supplied. I'm not going to try to make a silk purse out of this sow's ear. Some designs are fundamentally flawed and aren't worth the effort to try to rehabilitate. This is one of those such designs: its only merits is in trying to relive ones youth.
Axle wings:
Skin adhesion on these models was always a problem and it was always solved in much the same way:
Fill any obvious dents or depressions with lightweight spackle - even on a brand new kit this was sometimes a problem. Those were the days!
Then wing bag the wings with 2oz cloth all over and maybe a bit more at the roots and LE's. This forces the resin into the voids and pretty much takes care of the delamination problem. If done right, there is vast strength increase and very little weight penalty. If you want to be super cool with a glasslike finish, then wax up a couple of mylar film layers and tape them at the LE or TE (TE is best) into an "open book"and bung the glass onto them first before bagging the entire caboosh.
In any case, as I remember the wing was only about 7% thick so they need a bit of help - but I could be wrong on that after 50 years or so.
Axle Fuse:
For the fuselage, there needs to be reinforcement around the wing "axle' whatever you do. We used to start with a couple of nice 3mm layered/chamfered to 6mm birch ply plates epoxied along the wing/axle area. Now we have industrial adhesives that can take care of the polyester/epoxy bonding with a little surface prep, but then it was sawdust mixed with epoxy.
After that lay in glass wherever you can get it. Again, now that can be done with industrial adhesives, and with a high probability of sucess, though you might have to warm the mix up a little to get it wet enough.
The bonding strength of these newer industrial glues is phenomenal.
After that, a bit of sandpaper, some elbow grease and a couple of rattle cans plus a few cool stickers will see the flying speed increase phenomenally - as these things do.
