S8r problem not encountered before…..
Timzart
Hello to all, have run up on an unusual problem I cannot sort out with a set up of a new extreme flight muscle coupe with an s8r.
I have 7 of these receivers running now so fairly familiar with set up protocol, set up with independent aileron servos with second ailerons on the appropriate channel 5. With proper inputs and mix , the ailerons work correctly until the gyro is activated, at which point the ailerons operates properly from stick input,but when you check the active gyro correction directions, the second aileron does not respond to any gyro correction ? I went back into set up to make sure Chan 5 was not set to aux, set to aileron , and even ran thru Chan 12 calibration procedure 2nd time to see if perhaps it might pick up… no ceegar.
have had to drop back to ailerons on a y on single channel to achieve gyro correction on both ailerons? This gyro does not seem to recognize the second aileron channel? Any help appreciated!
after doing some searching I found this has been covered 9000 times here.... sorry will do more searches first before clogging up the forum.
did I find the answer.... not pe'zackly , but I have a little better idea of how to hunt it down, appears to be set up correctly... but not getting what I want, imagine that?
