Oh, I haven't setup the gyro rx with a delta, but this isn't like a "controller". For example, on my helicopters I use a 3 axis gyro and all the mixing is done there. The gyro here is not that. My suggestion is to turn off the gyro feature of the receiver and get the mixing right first, then turn on the gyro and set it up.
If you disable the gyro, the radio setup should be simple. Elevator should move both surfaces in the same direction, and if not, reverse one output. Then it should be a simple matter of setting the correct direction for ail/ele
Actually, the S8R is
exactly like your 3-axis gyro, and all mixing (and reversing) for delta/flying wings (or V-tails) is done on the receiver.
If you use any of the stabilized FrSKY receivers,
DO NOT reverse servo throws on the Tx the way you would on the OUTPUTS page if you use a normal receiver. If the servo is moving the wrong way, you must use the STAB lua script on the radio to reverse the servo in question at the receiver. This script programs settings on the stabilized receivers. Alternatively you can use an app or a USB adapter and computer program.
Why? Because reversing the servo at the radio will cause it to move the right direction if you move the stick, but the receiver will still move it the wrong direction for gyro or autolevel modes. In other words, the receiver always says that up is "this way", but if you move your stick and up elevator gives you down elevator, and reverse this on the OUTPUTS page, when you move your stick the output will now be "that way" instead of "this way", but when the gyro/autolevel engages, it'll still say that up is "this way", which is now backwards from your stick movements. And things will go bad quickly. Hence, you must leave the reversing normal at the radio, and if a servo moves backwards change the receiver reversing settings to change the servo direction.
You do not want to disable the gyro for setup. You must leave this engaged during setup
. More specifically, you leave the auto-level engaged during setup. Once you verify that all controls move the correct directions with both the sticks and auto-level system, you're good to go and can engage/disengage the auto-level/gyro as desired.
Solved!
I changed the order of channel/function
So instead of channel 1 being ELE and channel 2 being AIL, it’s now the other way around.
Reversing the servos doesn’t change anything.
But now I have going the same way when applying elevator, which is probably going to make it easier to fly the damn thing
Thanks for your suggestions guys
Glad you got it fixed. Note that the manual also specifies that for delta/flying wing, AIL is channel 1 and ELE is channel 2. So you were correct to flip these channels.
See my above explanation for why servo reversing, if needed, must be set on the receiver and NOT on the Tx OUTPUTS page. You set reversing per channel via the lua STAB script on your TX (or phone app or computer, depending how you prefer to setup the stabilized Rx settings). I just went through the setup on my SR8 (which appears to have the same setup and channel order as the S8R) last night, so let me know if you have questions and I'd be happy to help.
Before you fly, be sure to not only check that the controls move the correct directions, but also engage auto-level mode and move the plane. Verify the control surfaces move the correct directions to level the plane as you tilt it away from level. For example, tilt the plane as if it was in a left hand turn, and the elevons should move to force it into a right hand turn. Tilt the nose up, and the elevons should both move down to try to force the nose down. And vise versa. If not,
do not fly until this is fixed!
