I started playing with these receivers with a Horus x10s express using open tx. I can get thru the software update and calibrating the 6 sides
of the receiver. I setup channel 9,10,12. I setup the plane without stabilization first getting high low rates set and throttle end limits set.
I have noticed on the outputs page for setting endpoints on channel 3 (throttle) if the first number is below 400 (high is 512) then when toggling the switch 3 times quickly
to start self check mode (blue light) will not come on and servos will not cycle. I guess my question is if i set my end limits for the throttle and that
first number is less than 400 how do i get the receiver to do a self check toggling the switch, I can push the bind button and it will do a self check anytime (is pushing
the bind button the same as toggling the switch), problem with pushing the bind button is sometime the receiver might not be accessible to get at
the bind button. I can always set the number above 400 initially to get thru the self check process but then the servo is binding up until i can readjust the endpoint numbers back
to where they need to be. I can always unplug the throttle servo , do the self check then put my endpoint numbers where they need to be for the proper
throttle movement and then plug the throttle servo back in, , seems like alot of unnecessary work though. Does anyone have the solution ,thanks in advance.
