S6R configuration with UNI-RX V83
gorc
Hi all,
I successfully flashed firmware UNI #83 in my S6R, bind and activated. S6R now works fine with servos.
Next step is to calibrate the joystick and it's sensors.
Can I calibrate everything with the FRSky Free link program or must I (mandatory) use Mike's B. Sxr.lua script to calibrate S6R with V83 firmware?
I'm not sure if I can do everything with Free link or Mike's script must be used for V83.
Thanks,
gorc
You must use my script. It is much simpler and does the calibration and self check type operations in one go.
Mike
Thank you Mike.
However, I must use the standard PC config program to set the wing type? Correct?
This is what is explained in the PDF procedure.
gorc
