S port info?
Chrisk7
I have an AR Systems Xtreme PRO in a large scale plane. I've been running it through a Sbus connection from my FrSky TDSR 18 receiver off the ch 16 pin set for S bus in the transmitter.
I have a Zavionics widget installed in the X20S transmitter for reading the telemetry off the AR systems board but it isn't reading the telemetry from the AR board, only the receiver.
I was told to run the receiver in S port mode but when I change the ch 16 pin to S port nothing works, like the receiver isn't seeing the AR unit.
Will any channel or pins work for S port or does it need a specific channel or pin setting?
What am I doing wrong?
I was told to run the receiver in S port mode but when I change the ch 16 pin to S port nothing works, like the receiver isn't seeing the AR unit. bitlife
Make sure you're using the correct pin for S.Port on your receiver, as it often isn't the default "Ch 16" pin. Verify that your receiver is in S.Port mode and that telemetry is enabled in the transmitter settings. Double-check wiring, ensure firmware is up-to-date, and confirm that the telemetry widget is configured to read from the AR board.
