Flying Dutchman
Strong User
I tried to update my RX6R (ACCESS) from 2.1.0 to 2.1.7, but right before the end (progress bar almost full) the process aborted. I don't recall the exact wording of the error. Tried to do it again, but now it refuses to even start the update. When I do, it shows the empty progress bar and "Device reset...", red LED blinks once, "FW update error, Not responding, [EXIT]", and that's it. Tried to Register or Bind, just in case the previous FW might still be working, but nada.
Tried to reload 2.1.0 (ACCST), but get the same messages. Interestingly, the ACCST 2.1.1 update has an option to "write to external module" which I also tried; it does a complete write, with an encouraging "Flash Successful" message at the end, but still no bind possible.
Is it bricked, or is there a way to revive it?
Using a QX7 ACCESS (2.1.6) connected with the S.Port cable that came with the Rx. Plug polarities are correct, the update seemed to go fine, until it didn't. Rx ran fine before the update attempt.
