Greetings,
I recently purchased a pair of new RX6R receivers, and an RB-20. After the tedious process of soldering the Smart Port/S-Bus connector to the board (whew!), I tested each RX6R receiver individually, and all works as expected. I also tested the RB-20 with a pair of known-to-be-good X8R receivers, and all works as expected there, too.
The problem I'm facing is when either (or both) RX6R is connected to the RB-20 using the provided cable harness, the RX6R doesn't seem to power up when power is applied to the RB-20. (the provided RX6R harness has a normal 3-pin connector for the Smart Port, and a single pin, "signal only" connector for the S-Bus. These were connected from the RX6R to the Smart Port and S-Bus ports on the RB-20.) I then tried connecting a receiver battery directly to the RX6R, and all servo signals and telemetry are active via the RB-20, but when I rely on power "pass through" from the RB-20, the RX6R simply won't power up.
Summarizing:
Does receiver power HAVE to come via the S-Bus connector, and not the Smart Port?
FYI, the RX6R is still on the initial software release, so there are no firmware updates to apply.
Any ideas?
Steve
Summarizing:
- RX6R standalone - works (servos connected to receiver function normally)
- X8R standalone - works (servos connected to receiver function normally)
- RB-20 (power via MPX connector) + X8R (power from RB-20 via S-Bus cable) - works (servos connected to RB-20 function normally)
- RB-20 (power via MPX connector) + RX6R (power from RB-20 via Smart Port cable) - receiver fails to power up
- RB-20 (power via MPX connector) + RX6R (power via direct connection to battery) - works (servos connected to RB-20 function normally)
Any ideas?
Steve
