I notice the x20 has a snap roll on the mix menu, but the X18 doesn't. So for the X18 I set up 2 Var mixes- one for each aileron, on the same switch. Is this the best way?
I notice the x20 has a snap roll on the mix menu, but the X18 doesn't. So for the X18 I set up 2 Var mixes- one for each aileron, on the same switch. Is this the best way? uno online
Setting two variable mixtures for each flap on the same switch is a valid approach to achieving the fast flip effect on the X18. This method allows you to control the flaps independently, which can enhance maneuverability during fast flips.
