Ridge Runt Evo - Build Thread Comments
It would appear that the best way forward on the electric fuse. is to just rotate the elevator servo tray around to the rear side of B2, then reroute
the Bowden down the left side of the Fuse. Fabricate new supports for the cable at B3 & B4. It might help the curvature of the cable if the servo
was mounted upside down also.
TOM
Let us do a little flight testing on the electric. We will either have a tray that slips into the back of B2 with the servo on the correct side, or we will have the stand alone tray that fits back a bit further and allows the battery to pass through B2.
OK no problem
Tom
Any receiver should fit. Plenty of room. But a 4 channel is all the more you should need. I generally like the 6 channel units from FrSky as my go to size, but that is just me.
You guys build airplanes and i build kits
Ridge runt kits batch finished today
If you were like me, you glued one side of the fin to the fuselage before you were supposed to!
Well, one mistake I thought I made wasn’t a mistake after reading some other posts… the trailing edge of the wing didn’t reach to the end of the wood on the fuse, leaving about 1/2” gap or so. Turns out most everyone did the same. I thought I goofed it up.
What are people doing about hinges?
Hey guys - For hinging, I suggest using the covering hinge. This is when you cut some squares, flip one over and iron them to one another:
attachment.php
And you put these in alternating pairs. I like to have a pair right at the control horn, and then a few more pairs along the surface. Why do I suggest these? They allow you to perfectly center the flight surface, and they work really well. A taped hinge is easy, but can lift over time, or allow the control surface to sit a little high or a little low. We really want the aileron to wing joint smooth with this airfoil, giving better roll authority.
One of my glider elfs jumped in and used a simple tape hinge and my hinges are all sitting proud of the wing. I'll do a little surgery to fix them.
attachment.php
About how wide are your squares?
You can make them any size, but about a 1/2" x 3/4", and then you overlap about 1/4". You may want them a little longer if you are covering a fat flight surface. There should be videos and what not for this.
