bracesport
SO to cut a long story short I have followed a friend over here from the FT forum as we have been migrating our builds into other forms than foam board - I really liked the work @thenated0g was doing on a retro Ridge Rat build and I wanted in - Mine was going to be a CF braided sleeve over a green foam core for the fuse and 3D printed wings with a monocote skin - simple!
But along the way, I had this idea to make a twisty - to make it work I needed to add another CF tube as the wing mounts as the original ones were not in the right positions for a wing pivot, and invent a rotor mechanism that allowed me to maintain the low mounted wings!
Here is the progress on the twisty conversion to catch you up to speed - I cut off the second wing mount to use the front one as the wing pivot mount - I added a drive pin into the original front wing mount of the wing - I removed foam from the fuse and glassed the internal surfaces to stiffen the void - I trimmed the side holes for the drive pins to access the fuse - Then I dry fitted the wings and rotor mechanism into place - so far so good!
