Ouch! Sorry to learn of this. Looks like some kind of failure not allowing for the flair (turbulance or RF link).
Can we see the failure? On my slopes this seems to be a knock against the Aeroic models, that is the guys claim the fuselages fail far too easily (Schwing Corsa 108 and Stormbird) I suspect it has to do with the lay up and the fact that most Aeroic models have a long nose adding more leverage.
While the Redshift is a new design it does have many element of old. Like the top loading servo tray. Most new designs are now bottom servo trays, as it allows for the top of the nose to carry much more of the impact loads from a typical landing. The top load servo tray tends to allow the sides of the nose to buckle outwards (the nose cone was an attempt to control this).
The shot gun ballast port on the bottom does remove a lot of structural strength from the nose. It was thought that the added carbon ballast tube would replace this lost structural strength by being a carry through spline. I’ve learned to really pack the opening with fiber and epoxy. (I hope that the epoxy soaked cotton balls work). I also carried the 3mm plywood servo tray aft past the fuselage part line. I laid 3.7 oz Kevlar cloth on this tray and bound it to the fuselage sides that were above the tray. I think I now have a much stronger nose and fuselage joint that what was originally offered with the glass servo tray and the square ballast tube.
On the next Redshift (II?) I’d like to see a bottom servo tray and the nose cone part line slanted about 7° to be closer to 90° to the normal impact force. ( This is now standard stuff in most larger slope ships)
Thanks for the feedback on set up values.
Doc, Wayne, this brings up a good question. Now that Doc has lost control of the original molds how does one support this model with parts?
