Redshift; Used Purchase
Status
Not open for further replies.
I’ve been hearing rumors that some manufactures are using yellow polyester cloth as a fake substitute for real Aramid fiber cloth. To date I have not seen this. All the “Kevlar" (Aramid) fibers I’ve seen in both the RCRCM and Aeroic model seem to respond like real Kevlar. That is the yellow fiber is horrible to sand and is tough!
Now not all live hinges are made from Kevlar. My Mibo models have a polypropylene insert that is used as the live (flex) hinge.
Back to the subject of the thread (I have no idea how we got side tracked into V-tail verse whatever. Or how computer generated airfoils perform in the simulators verses the wind tunnel).
Here you can see that I’ve removed the wire horn and cleaned up the left over epoxy. I’d like you to note that the live hinge appears to be Aramid. You can see the fiber fuzzing from being “Sanded”.
I have this photo taken on top of the Aramid bias cut cloth I’m planning to cut the replacement hinge from. This bias cloth is 1.7 oz/sg. yd.. Unfortunately this hinge patch will be rather narrow to fit between the stab and control surface facings. I fear that it would be far too easy for the fiber threads to unravel. So I gave the cloth a very light coat of 25% nitrate dope and 75% thinner to bind the fibers to each other as I work them into position. I hope I’ll still get enough epoxy saturation to make an adequate live hinge.
Its only the last few models - none of which went to USA that had the Rayon Konrad.
I actually have one here.
You lost me. Are we talking about the material used by the last Aeroic OEM. Or are we talking about high fashion on the Paris fashion runways?
Rayon - a cotton carbohydrate. That is easy to test by flame. It would smell like burnt paper. If it was silk it would smell like burnt hair.
Thats a very good idea Konrad. I can see it going down...
"Hey Mr Aeroic seller, do you mind if I test this wing to see if the Kevlar is actually Kevlar, or some other fibre? See - all I want to do is hack out a piece of the hinge to test - look, I brought a hacksaw, a chisel and a Dremel with me. I even packed a blowtorch so I can do a simple burn test so that we can smell if it smells like paper or hair burning.
"What did you say? Epoxy matrix? Nah you'll never smell that burning!."
"OK then - in that case, why, not at all Konrad - what a novel idea! And a very smart thing to do - be my guest, I'll even get one of my staff to clamp the model down nice and hard in this large rat-toothed vice to keep it still !"
Haute couture rules...
LOL- So true and so sad; Haute couture rules...
Like the Canon ad says; Image is everything!
The flame test is a quick and dirty test much like the grinder spark test is to identify the family of metals one might be looking at. No need for the blow torch, a simple cigarette lighter usually is sufficient.
The flame test is a quick and dirty olfactory essay and ash test for textile fibers. It is not intended to be the definitive tool used to identify the make up of the fibers. You can read how I used it to identify the glass fiber on my Mefisto here. https://forum.alofthobbies.com/index.php?threads/mefisto-build-blejzyk.284/
If the flame test smells like burnt paper the fiber is a carbohydrate like cotton, linen, hemp etc. If it smells like burnt hair/skin it is likely a protein probably silk.
And since the family of material that our toys are made from is known as Fiber Reinforced Plastic (FRP), burnt epoxy smells like acrid plastic.
You might have notice that I don't claim that the torn live hinge on my used Redshift is Kevlar. What I say is that based on the (fuzz test) that the fiber is acting much like an Aramid fiber.
Yikes, I wasn’t aware until you mentioned it in your post #82, that some Aeroic aircraft might not only be suffering quality issue from poor workmanship, but that they might also be suffering from fraudulent materials! I’d like to ask how you ascertained that some were built with Rayon as a substitution for Aramid fiber. I assume you have a much better no-destructive test, than my flame test.
Doc. I have some concerns that many of your posts don't seem to be helping support your brand. While I understand you wanting the throw Zhou under the bus. But please keep an eye on helping your dealer network sell your products.
How do 'live' hinges work? How are they made?
Good question. But with your experience haven't you been dealing with the live hinge in your models?
I'll give Doc. a chance to answer that as he is the designer of many models. But it is mainly based on the properties of the fiber (kevlar) and epoxy. Others use a polypropylene strip as the flex material.
Here is a place to start:
You might get some insight here. I use the term Mylar when the material might in fact be polypropylene.
I’ve been stalled a bit on the repair of this Redshift V1.0 until I've successfully repaired the torn live hinges on the stabilizers.
Much to my surprise the repair of the torn live hinge went rather well. As I mentioned before I’m using bias cut 1.7 oz Kevlar as the live hinge material. This kevlar has been laminated over the original failed kevlar hinge. I had some concerns that the new and old hinge not being on the same plane (geometric term) that there might be some binding. There is enough flex in the fibers that this isn’t the case.
One of the things that often bothers me, is to repair something one often has to subject the part to even more damage. In order to get to the damaged hinge I had to remove a lot of the wiper and I also had the remove some of the end cap webbing. I have yet to repair these features.
A big problem with repairs like this when we are dealing with small pieces of fiber cloth is keeping the fiber in place and bonded to the original structure. To help with this I’m using polystyrene wedges forced between the upper and lower skins. I chose polystyrene wedges in case I can’t mechanically remove them I can chemically dissolve them.
So far I’m ecstatic with the repair! I’ll need to wait another 12 hours to make sure the kevlar is bonded to the control surfaces. Once that is verified I’ll need to add the control horn and repair the wipers and end cap webs. There is also some cosmetic damage that I should address.
Once I’ve gotten the tail surfaces repaired and operating to my satisfaction I’ll get back to the other issues I have with the rest of the model. I did buy a set of KST X0-8+ and I'am pleasantly surprised that KST has an upgraded KST X0-8+ V2.0 (reinforced gearbox).
One of the things that often bothers me is to repair something one often has to subject the part to even more damage. In order to get to the damaged hinge I had to remove a lot of the wiper and I also had the remove some of the end cap webbing. I have yet to repair these features.
A big problem with repairs like this where we are dealing with small pieces of fibers is keeping the fiber in place and bonded to the original structure. To help with this I’m using polystyrene wedges forced between the upper and lower skins. I chose polystyrene wedges in case I can’t mechanically remove them I can chemically dissolve them.
Once I’ve gotten the tail surfaces repaired and operating to my satisfaction I’ll get back to the other issues I have with the rest of the model. I did buy a set of KST X0-8+ and am pleasantly surprised that KST has an upgraded KST X0-8+ V2.0 (reinforced gearbox).
View attachment 2967View attachment 2968
Great Job Konrad!
Thanks Doc.
Here is the initial fitting of the control horns.
You will note that I've installed the stabilizer "upside down" so that I now have bottom hinged surfaces. This allows me to now have control horns that are nominally 10mm long (hinge line to clevis pin). This should be close to double what I measured with the spherical joints, when I started this repair.
Rather than wasting my time watching American football on Thanksgiving day (American) I took the opportunity to cutout a plethora of control horns. Not knowing what would actually fit, the arms vary in length a bit. What I don't use on the Redshift I'll use on my white Strega.
Well 24 hours later and after my usual post cure heat treatment, I can say I’m happy with the live hinge repair.
I have to say that at times I’m shocked at what passes for a modeler. When I'm working on this high a level of model (performance and cost) I’d expect that the original owner/builder would have a certain level of competence.
(F3F is not an entry/beginner level model. And the RedShift isn’t an entry level F3F ship)
I have to say that this used Redshift has had more than its fair share of builder issues! Early on I mentioned how easily the servo tray came out. This is because the builder failed to roughen the fuselage prior to glueing in the servo tray. I was shocked to find that the ballast tube was only glued for the first 30mm of its length. This would have very likely broken free on a moderate landing. Also as the length of the ballast tube was not glued to the fuselage it did not offer any stiffness to the fuselage. Again this could allow the fuselage to fail early. I was also dumb founded that the flap and aileron push rod had bends in the threaded portion of the push rods. This will cause the push rod to fail!
And last (so far) is that the builder used a double splice in the wing/fuselage wire harness. And to make matters worse these splices weren’t staggered. Double spices offer twice the opportunity for failure! Non-staggered splices make for a very bulky harness that often doesn’t run well in the fuselage. I don’t know what issue the original builder might have had. But if he needed a bit more length untwisting the harness often gets this hidden length. If for clearance issues he needed a portion of the harness to be a flat ribbon. Again the area of the run could be untwisted and with a heat gun the wires could be “trained" to lie flat.
To learn to address build issues we have entry level models. An F3F ship is not the place to learn how to build a basic model. I blame the fact that in the USA shop classes (vocational training) have be eliminated from our schools. I also blame the loss of kits to the ARF epidemic. Without the opportunity to learn before making such a high performance purchase these issue and frustrations will continue.
Please don’t confuse these quality build issues with personal preference. And don’t confuse design issues with build issues.
Konrad, Konrad, Konrad - guilty as charged, and what a very, very naughty boy I am.
But why, I wonder, would I have done such a sloppy job? I'm casting my mind back two years as I write, and its all coming back to me...
Yes! The fuselage was not sanded internally! - or at least I don't remember sanding it.
Yes! The epoxy used was the local 5-minute pot life type that often sets before it really bods with anything.
Yes! The control rods were convoluted, canted, and kinked!
Yes! The wiring was joined - and horror of horrors - in the same position!
Yes! I made the ballast tube top access instead of shotgun type!
Yes! The...hang on...I bet there were more crimes...I'm sure you'll find them.
I'm sure I should have done a much better job building up that model. And the other one I built alongside it too. Absolutely no doubt of that.
But given the circumstances I'm not at all surprised, since I had only 8 hours (12 actually) to complete TWO MODELS.
Due to a totally unplanned 3 -day overrun on a consulting job (model aircraft is not my "day Job") It was start at 8AM with TWO (1+1=2) models that were not even unpacked:
For the wiring I had none - so ready I adapted from the only half done set I had, which was for a 4 meter plane.
For the bonding - I just used the fastest way and the fastest curing method could think of.
For the shotgun ballast access - really no time.
For the servo controls - it was just cut and bend anything that works and hopefully sort it out later with new (better made)rods.
Then it was packing at 6PM and off to the airport to fly to USA at 9PM.
Red handed! Guilty! You may slap my wrists unmercifully next time we meet!
You built it?
I didn't want to name names, I just want to show what one would want to avoid.
You are a bigger man than I.
By the way what is the 5 min epoxy? It appears to be a good brand. Most 5 minute epoxy never hardens
Edit:
I didn't want to name names.....
You built it?
I did want to name names, I just want to show what one would want to avoid.
By the way what is the 5 min epoxy. It appears to be a good brand. Most 5 minute epoxy never hardens
Hi Konrad - yes I "built" both models in 8 hours total.
This is NOT RECOMMENDED by the designer.
For reference, the one you have is either the third or 4th out of the moulds so in any event the build was a bit trial and error - in this case, more error than trial it seems.
The epoxy I used is not 5 minute epoxy - just acts like it. Its old style amine (ammonia smelling) epoxy but has a very short pot life due to being about 3 years or more old. Useless for laminating but still cures hard so OK for bonding - if you sand the surfaces first! Sets hard in about 8 hours.
It acts a lot like the Aloft 30-minute epoxy.
TBH I would never use 5 minute epoxy in any model unless it was a field repair that I was going to re-do once I got home. Thats about all its good for IMHO.
Meanwhile carry on the good work...you have gutted the model pretty much - so stripped out most of my bad, very hastily done crap. Eventually you'll end up with something pretty good I think.
Doc, I knew you were once an owner of this bird. Hard to miss with all the sticker on her. Sorry, I didn’t know you did the build. I had assumed it was done by somebody else, much like the Aloft Schwing Corsa 108 demonstrator, bouncing across many owners.
This ship might explain why we didn’t see you racing at the 2018 ISR.
Damn, I was hoping you had found a good strong 5 minute epoxy. I too use almost exclusivly amine epoxies. And yes they have a short pot life. This is why I keep the pot of epoxy on a blue ice brick. I have no issues with the Smith Industry epoxy (hobby) sold by Aloft hobbies. In fact I like the 15 minute type, it cures rather hard. But the 5 minute epoxy performs just like any of the other consumer grade 5 minute epoxy.
I need to be clear. I have no issue with the purchase of this bird. Wayne made it clear that it had some issues. We came to an understanding on the price and I know I got a more than fair deal. Even having to take the ship down to the frame. This has actually helped me address one of the few design issues I found, too short a set of control arms.
I still need to get a set of brass wing ballast bars. Is the wing set up for 10x20 or 10x19 bars?
10x20's Konrad, but I'd get the suppler to linish the surfaces a bit on a belt sander just to take it down a little if possible.
I made 4 bars for each wing only, and added the appropriate wood spacers to make the set.
I have the Redshift ballast chart, too made by the UK F3f team if you need it.
We'll be there this year for ISR and Sunset C&F and you never know what I might bring with me - hopefully well set up this time.
BTW the Aloft Demo Corsa was not me.
Doc
Nigel in South Africa maidened his Redshift at the weekend -
Nigel says:
"Managed to maiden the Redshift. Flew straight as a nail from launch. Had really good fun. Bought a new frsky radio. Basic setup got me flying. I have downloaded Mike Shellim f3f program for it, but need to load it on the radio. Thanks for an awesome plane."
Looks like a really cool flying site!
I do see the one plane eating tree!
I have about 5 minutes stick time on the Aloft demo Redshift. I flew her at the 2018 ISR. She was about the fourth 3 meter moldie I has ever flown and the first F3F ship. Not knowing anything about F3F ships I did like how she maintained speed in the turns*. I don't recall having any double centering issues that Wayne was complaining about. But then again, I kept her up high and really didn't wring her out.
I'm coming to really like the Mike Shellim templet on all my 6 servo slope ships. I use it with the Strega.
* I flew a lot of FAI F3D pylon and can really appreciate a ship that comes back like it was hit with a tennis racket!
I think the Aloft demo Redshift has a slight issue with cross talk. That is the tail control horns (spherical joints) make contact with each other as they move. I think dropping down from the 5mm ball to a 4mm ball might gain the needed clearance back there.
Dropping down 1mm in ball size will effectively add 0.5mm to the a horn length. That's a 10% improvement using the measurments I got with my Redshift.
Status
