Did I read that correctly that you have lowered the stabs by upping angle between the stabs from 104° (as designed) to 109°-115°. I have to ask why the 6° variation?
Yikes, I see no stability in the stab joiners (img #9075). Those joiners are to extend all the way to the other side of the fuselage! You have the option of imbedding the joiner end in a puddle of epoxy inside the fuselage. Or do as the designer recommends and punch through the fuselage side to gain the much needed stability and strength. As I see it you will always be breaking the stab mount!
The dent, I'd lift it out with a bent pin. Inject water to swell the balsa wood fiber. After the water dries (about a week) I'd inject some thin CA glue. Now if I was willing to do some paint repairs I would do a classic lay up repair.
As to the structure showing through. Well that is as a result of the thin balsa skins and the unstable epoxy use by the OEM. Over time the epoxy shrinks. I'd leave it alone to save on paint weight back there. Now if you can paint then do block sand the surface for better airflow and control. But watch the weight build up!
