Well, the other flap control horn popped out. This has to be the bane of sub-contractor work. Such a minor process omission as sanding the control horn costs so much. In my case this cost some damage to the wing wiper, but more important it cost me the ability to keep flying the Redshift in a race.
I knew I should have pulled this horn out as the other side had demonstrated that the bond was totally inadequate. But I feared that my "controlled" attempts to remove the flap control horn would result in more damage to the wing. As it happened the operational failure of the bond result in less damage than what I'd have expected had I attempted to remove the horn.
Now I haven't dealt with this control horn bonding issue as I normally install my own control horns (spoons) in the way of IDS installations.
While this OEM (Zohe?) results in products being much better than what we get with RCRCM. I ecstatic that Aeroic has dumped this OEM (Zohe?) for one that routinely makes ships that withstand the forces of DSing. I know Aeroic doesn't condone DSing with its ships, it is nice to know that there has been a huge step up in quality.
Hi Konrad. Its "Zhou" and yes this is one of the things that really gets my goat.
Question 1 to the manufacturer: How long does it take to abrade the bottom inserted sides of a G10 insert?
Answer: Possibly 10 seconds? Not even one minute per model?
Question 2 to the manufacturer: What is the impact of
not doing this? (sorry for the pun)
Answer from the manufacturer: The model might crash so he will need a new one - Hooray!
Answer from the designer: The model might crash and cause injury but at the very least will probably be badly damaged or destroyed.
Little things like this, begin just like that - a few little things, then it goes to more little things, then when added together you end up with a model that is dangerous, and thats where I got to with Zhou. I had three models crash because of negligent manufacture and that was it.
There is a phrase often used in the Chinese language: "Tsa bu Duo" It literally means "Not so different" but what it is used for is inevitably an excuse for not doing a job. Abrade the control horns/not abrade the control horns = Tsa bu Duo...
Zhou Quote: "Our workers don't like to make models your way as you are only the designer" Ho Hum.
Like it or not, these slope toys are inherently dangerous, so as a responsible person purveying them, the very least I can do is to make sure nothing in the manufacture could cause catastrophic failure.
But now there is light...Now I have a manufacturer who LISTENS. If I explain why I want something done just so, then he can see the logic and sense in it. I have seen this creeping into the models recently - they are getting turned out better in every way.
More news:
Soon my new guy will move to a new factory which will be better organised and utilised than the original, and that will include SOP "Bible" instructions for each process of each model manufacture and will include a thorough quality system from incoming materials, through manufacturing steps to finished models. I'll go to China later C19 permitting and get it all set up.
I still have nightmares about Zhou - I mean really I do.
