Well I can now say that I've recovered from my error flying my Redshift in the back side of the hill.
I took the opportunity to test fly all three of my F3F ships that have been badly damaged by my poor flying skills. The wind at the SLoT was from the east varying E by NE and E by SE with velocity varying from 8mph to 16mph. This is know as light lift conditions at the SLoT.
Much to my surprise all three ships flew out of my hands with no trim changes need to the normal cruise flight modes. All three ships are trimmed for a very neutral CG as they will not pull out of dive. I saw no tucks but no pull outs ether.
This was really a surprise with the yellow Strega as I had torn off the V-tail in my last tango with the rocks.
But as this thread is about my RedShift I was ecstatic by how the repaired Redshift flew. As you might recall I slammed in the back side of the hill which resulted in all six control surface tearing off at the kevlar hinge. I also tore free one of the wing boxes.
The repair of this Redshift has been rather frustrating as I've made approximately 4 attempts to get the repaired Kevlar hinges to work. Also the wing box damage was tricky to repair needing a lot of access holes to inject the needed epoxy.
All these repair attempts combined with some of my defeatist attitude has left a lot of epoxy finger prints that I'll now have to buff out. But the flight test has shown that this will be worth it.
Today I spent 4 hours at the SLoT with a good hour of this time spent trimming the Redshift and sport flying her.
I had the opportunity to compare the RedShift to the Stregas in the same light lift. The Redshift was heavier than ether Strega as it is a carbon lay up and the Stregas are a glass lay up.
Much to my surprise the Redshift out flew the Stregas at both extremes. She was about 30% faster in the straight line speed runs. This was expected.
But when the wind stopped the Redshift actually out thermalled the Stregas. I had some fears that the narrow tips would prove to be a problem at these slow thermal speeds. But nothing could have been further from the truth. Maybe I was particularly more aware of airspeed with the Redshift, but Strega would drop a wing in a tight thermal turn. I never saw this in the Redshift. I don't know if I didn't feel I need to go as slow with the Redshift or if the wings just held on longer prior to a stall. I attribute a lot of this of this thermal performance to the longer wings and higher aspect ratio. The Redshift thermals wells. I did notice more wandering in yaw when the Redshift is slowed down (not in crow). I may have to work on the aileron differential a bit. Also in the high speed runs the tail wiggled more than I thought was prudent.
In landing I noticed a marked difference! The Redshift was upset in roll a lot less than the Stregas. Also she took longer to slow down. Again empty the Redshift weight more also the flaps are shorter and of less area than the Stregas. But if one waited the Redshift did slow down to much the same landing speed as the Stregas, but with what felt like more control.
I tried to test the wing box repair with fast sharp pull ups. But with the lift and no ballast I can't say as I've actually tested the load capacity of my wing box repair.
I'm tickled pink that I was able to repair this Redshift to be at least my sport ship. I hope to test her some more this Saturday with a coastal F3F race.
I'm now anxious to finish my Alpha 2.8 with her longer tail boom and larger V-tail to see if I gain some more directional control at low speed and if I loose some of the high speed wiggle.
I'm also working on my second Redshift. I hope I can treat her with bit more respect and care than I did this one.
While not the super bloom of a few years ago the landing zone was beautiful!
