That was fun! I have to admit that I was dead last of those that had flown an F3F race. I blame the fact that I didn’t have adequate ballast. And I allowed racing to interfere with my flight testing. (That’s my story and I’m sticking to it)!
I was getting a bit more attention than usual as I think this was the first Redshift most had seen flying.
There’s nothing like racing to show the errors of one’s set up.
While I think I’m not over flying the bases too much as witnessed by the may cuts. I am having a problem maintaining my energy.
My set up was CG 95mm to 96mm
Elevator was 7mm
Rudder was 7mm
Total V tail was 14mm up and 15mm down
Ailerons 17mm up and 10mm down
Aileron to flap mix 4mm up and 5.5mm down (Not enough and the differential is reversed)
Snap flap 2.5mm
Aileron to rudder mix 18 (units unknown)
What I noticed was that my aileron roll rate was rather slow. This forced me to remove all the differential adjustment in Mike Shellim’s templet leaving only the mechanical differential. You might notice that I’ve improperly rigged the flaps as ailerons with more down than up. On the hill I had to add some aileron to rudder mix to try to tame the adverse yaw.
I did suffer one high speed stall. I’m happy to report that unloading the wing the air reattached rather quickly with no resulting spin.
I have to admit that the small tip chord scared me when I first saw the Redshift. But the wing is very forgiving.
The only other high aspect ratio glider was a Fossa Lift. She was turning real well, better than I was turning the Redshift, and making noise doing it. My Redshift was dead silent in the very dry inland air, that or I’m deaf
The bad news is that I tore off a flap. The good news is that I can say the Kevlar used was properly biased as to allow all the kevlar threads to cross the hinge line. With the skills I’ve learned repairing the V-tail hinges the flaps should be a doable repair.
