WOW, The second maiden flight was fantastic.
Now many of you might recall that the tone of this thread was a times a bit confrontational between Doc and myself. This was mainly focused around the engineering. And to Doc’s credit he did admit there where some issues. The only fatal mechanical issue I noticed were the short elevator control horns. Doc has said that these and the few other issue, mainly focused on preference will be addressed with Redshift V2.
So to my mind the only issue left is how does the Redshift V1 fly. Today the flight testing consisted of about an hour of air time and 5 extra landings. I need to remind folks that I’m using Mike Shellim’s fantastic F3F OpenTX templet. The real changes from the first maiden flight are the re-mounting of the aileron servo, the added upward throw from was noticed. And the changing out of the DS125 servos for X10 servos. The maiden last week showed that a CG of 93mm was too nose heavy, making more trim flights non productive. This and that I was using 6v servos on an 8.4v battery put an end to test flying that day.
Today I started the flight testing with the CG at 100mm. While the Redshift was honest at 100mm, she seems a bit tail heavy as shown by the tuck in the dive test. And if pushed will flick into a spin if the elevator is pulled too hard. These spins took over 3 revolution to recover. Not a confidence builder if racing close to the ground! With a CG at 100mm she was controllable in all flight modes as long as you stayed out of the stall. Post stall took active controls to recover. You couldn’t let go and just let the ship build up speed.
After my heart rate returned to normal I placed the CG at 96mm to 97mm. The dive test indicated that this was the neutral point. I’m finding that the ailerons are a bit slow as I need to use a bit more aileron differential. (I expected the dual cusp airfoil to minimize this a bit). I suspect with the long time to recover from a spiral and this aileron differential that the Redshift needs more vertical fin. Doc. did say he was going to narrow the V-tail angle a bit. from 104° to maybe 102° and add a bit more area to the surfaces. Again I only have a an hour of air time and it looks like this might be needed. With the CG at 97mm she does track rather well through the turns. I’d like to see the mention of 90mm for the CG be removed from the manual, it really is too nose heavy and destroys much of the grace and elegance of the flight.
I’m noticing that the manual is correct in that the snap flap only needs about half what we currently use in todays crop of airfoils. I think this is because the airfoil has a bit more chamber than most modern airfoils.
I only flew the RedShift empty (no ballast). Now that I know the CG I’ll have to make up a set of spacers and trim weights. Even without a set of ballast weight I’m hoping to race her on Sunday. I’m torn should I stay home on Saturday and make up a set of trim spacers, or do some more flight test to get comfortable with her prior to racing.
I didn’t notice any unique sound to the Redshift. Maybe I haven’t gotten her on step.
With only an hour of flight time I can say I’m sorry Aeroic had so many quality issues with the OEM. I think we the flying public lost an opportunity for 2 years to have a great F3F ship at the $1500 price point. If you can find some old new stock It might be worth the effort to correct the short V tail arms. I think the threaded servo arms shown by Jonathan Wells, and used here by me, is key to making the Redshift V1 work.
I can only imagine how much better RedShift v2 will be. I don’t think it will be a drastic change in its flight characteristics. But it should address the short horns and have a narrower modern fuselage. Not sure how I feel about adding mass the the wings, dampening the roll, just to cut down the cross section of the fuselage. I’m not sure where the drag curves cross. For now I like the RedShift v1 and how she flies. I can only think how much better she will get as I get more and more familure with her.
Thanks Doc.
While this one was a bit more work (used purchases almost always are) I'm very happy with the result.
