As a result of family issues and that the race season is coming to an end I don’t think I’ll be racing any F3F until 2020. During the 2019 season I was using the very economical (read cheap!) and well dated Strega’s. These did what I hoped they would. That is give me a chance to learn what F3F is all about. For a plethora of reasons, mainly focused on their construction, the Stregas are not well suited for F3F racing.
While I have made huge strides in being able to fly the F3F course it pains me to say, I’m not at the piloting level to justify a high dollar multi grand set up. Luck would have it that I found a ship that should allow me to progress well into the next level of competency for 2020. I found a used Redshift that was in my price range. Actually the Redshift I found will allow me to run with the top competitors. Again I won’t be equipment limited.
The reason the owner was selling the Redshift was that he was complaining that this particular model was double centering on the elevators. After a protracted negotiation period I quickly gave him the cash and ran away as fast as I could before he came to his senses! Possession is 9/10 of the law!
It just so happens that both the Strega and Redshift are designed by the same man, Doc. James Hammond. It will be fun to compare these designs that are decades apart.
I need to stress that this is a used ship and I don’t really know the history of this model in detail. When I looked at this model I thought that the very short (less than 5mm above the hinge line) elevator control horns were the culprit for the double centering elevators. I now don’t think they are responsible for the problem. When I freed the push rods I noticed that there was a huge amount of drag in their movement. I don’t know what happened to the snake but freeing up the push rods will be the first order of business.
As a result of trying to get the elevators “adjusted” the kevlar hinge has been stressed (torn). I’m going to try to relay a kevlar repair, rather than go with a silicone repair. Since I’m back there hacking away I’m going to change to standard clevis connection. I’m doing this to try to get 1mm to 2mm more leverage from the control horns.
Looking at the fuselage there has been a huge improvement. First I like the huge full radius fillet at the front of the wing to fuse part line! This adds a lot of geometric strength to this highly stressed area of the fuselage. Second if that this fuselage uses a slip on nose cone. With the way Doc. has designed the fuselage it is twice as thick at the nose cone and fuselage part line. This gives the fuselage real good hoop strength, again in the highly stressed area of the fuselage.
The one draw back I see in the fuselage, is that at the wing joint as a result of that huge front radius the part line is not perpendicular to the wing joiner. As designed this means that the wing wire connectors are not parallel to the motion of the wings when installing and removing them. As a result it is not advised to try to make up auto plug-in harnesses.
On my model the ballast tube is a top loader. I learned from my Stregas that top loaders are a real pain when needing to adjust ballast at a contest! I’ll look into seeing what can be done to change the ballast system to make it a much preferred shot gun bottom loader. The slip on nose should allow for this.
