It flies in most folks hands, but not well. Like I said it isn't divergent. Or not as well as other models on the market in the same time frame. Most would have attribute this flight stability issue to the mechanics and I would agree as a result of the double centering problem with the snakes and the control arms (those are also design issues). But once those problems were solved the ship still does not go where you point it.I'm abandoning it too, Wayne.
- Its just repeat, repeat, repeat.
- The model flies OK in most people's hands.
- In any case the model is obsolete and will never be made again.
- The V-tail has been replied to unpteen times by me.
- The mythical relationship between the nose and the V-tail does not exist.
The model is still available (DON'T RECOMMEND GETTING ONE FROM THAT SOURCE!) And as there are 20? others that are still flying? The 96° fix is any easy mod for most owners.
Some might want to try this experiment. Acquire one of these, and get her trimmed to fly as you like. Now take the same area we have in the form of the rear vertical fin and add it to the front (nose). Re-balance the model for the added nose weight this fin adds. And report back your findings. I'm sure most will find that the added front vertical area will result in a very unstable aircraft. As this added front fin will be a destabilizing factor over powering the yaw dampening of the rear fin. In fact it will cause a positive feedback resulting in the ship yawing even harder as a result of the upset (cross wind launch). This is what the added side area of a large nose is doing, adversely effecting the directional stability.
This is nothing that a larger rear fin can't address but at the cost of added drag from the added wet area.
Here in this thread I was showing that moving the V-tail junction angle from the OEM 104° to 96° adds some of that missing vertical fin area to over come the nose with no added drag penalty from any added wet area.
Edit: difergent to divergent
