Yikes, that you have to ask that question.
But I suspect this is actually a trick question. And yes there are formulas to help us work through these control and stability issues. You know this as it was part of our aeronautic training. Now I don’t have any of your engineering data. So the numbers I used were derived off of my Redshift models by myself. I can’t claim that my reverse engineered numbers are accurate. Actually, you are the one that might want to show what are the margins of stability. I’ve shown empirically (that is where it counts) that when it comes to directional stability the Redshift as delivered was lacking.
Since you, on this subject (engineering), put so much value on concepts derived from models claiming that what works for in the real world of full size and Reynolds numbers doesn’t apply. I shared with you the writing of Dr. Drela *. He has some very concise writing on the subject. He also has some simple formulas for the layman. I also recall he even has an excel worksheet that does most of the work for you.
Now there are a lot of variable (factors) that control stability. Area, moment arms, dihedral angle, surface coefficients of drag just some of the one that come to mind. One can manipulate any one, or combination of these variables to get the level of stability one wants. Note the idea of level. As mentioned earlier the problem here is finding the proper relationship between spiral stability and directional stability. The solution to one is often at odds with the other. And then there is the weight one place on each variable.
For F3F racers historically the designers have placed too high a value on drag reduction over that of directional stability. This is why “I” think we so many V-tails in the F3F class.
We all know, well I do, that the REDshift needs a lot more vertical area in the rear or a longer moment arm to counter that expanded nose. As I didn’t want to make a new fuselage or new control surfaces “I" was rather limited in what “I” could do to bias the stability towards greater directional stability.
When looking over the design I was actually shocked to see that you had used the rather pedestrian V-tail junction value of 104°. I was shocked because you often say you don’t follow the crowd in your designs. You deprecate, admonish "the me to crowd”. Now I was relieved to learn the angle wasn’t 110°!
Now in the more advanced control formulas the aspect ratio of the wing is a variable we designers manipulate. Seeing that the REDshift has those fantastic 18:1 aspect ratio wing. I was really perplexed as to why you used the 104° V-tail junction, for a clean sheet design, that is best for 15:1 aspect ratio wing.
Now with all the constraints I placed upon myself to correct the REDShift’s directional stability, basically left me with only being able to manipulate the V-tail junction angle. I ran the numbers and to get a value for directional stability that I felt was suitable for plane flying in the environment we see in the real world of racing (not in the clean air of a wind tunnel) I had to bring the V-tail angle up way past 90° ( I think it was close to 60°, yikes). Per the drag factors discussed by Hoerner I wasn’t about to go under 90° **for a racer, heck any other V-tail plane for that mater. But this did show that narrowing the V-tail angle nudged the stability in the right direction. This fit perfectly with my fix for the mechanical issue I had in the back, with leverage from the surface control arms.
Now I did take things slowly (not my F3F speeds
) and changed one thing at a time. first the mechanical fix with the tail flip and its slight aerodynamic hit. Then the 100° degree junction experiment, and based on that success the latest iteration this 96° V-tail. I could still go all the way to the Hoerner 90° limit, but then I think I’ll be flirting this pitch stability more than I’d like.
If I go any further with the REDshift design I will need to make new hardware not just make adjustments to the OEM hardware. Yes, your wing warrants that kind of work. But as I think there is a new ship just over the horizon I had high hopes. But with the few pictures (cartoons, non-engineering drawing) I’ve seen I fear the directional stability issue/solutions might not fit with "my expectations" for an F3F racer. (To be fair you aren’t claiming the next 3 meter ship to be an F3F racer).
* If you don’t like MIT professors, Don Stackhouse also has some easy formulas for finding the proper sized V-tail for a model airplane. He goes about it from a different angle (pun intended) but comes up with numbers similar to Dr Drela’s. I love the power form his V-tails and like you he too had some mechanical issues with his last design.
Both men have published these in the toy press. There is a lot of this in the real world of aviation, but I know you don’t put much validity on that part of aviation as it pertains to our toys
**I’m putting 90° as a self imposed limit
