Sorry this is going to be a bit of a bitch session.
CAD, or more to the point poor CAD work drives me nuts! Far too often folks confuse CAM with CAD. CAD is Computer Aided Design. The key concept here is Aided Design!
Design is Form Fit and Function! Now I admit it has been 20 plus years since I actually drew out anything in CAD. Back then I was using Catia v5. Key to this work was to check Form and Fit. This included clearances need to actually build assemble the system. I'm sorry to say that with this Redshift Mk1 this was not done. We had the leverage issue with the V-tail and then this horrible issue with fitting the flap servo.
I'm not going to guess where the fault lies, be it with the contract, or data supplied to the CAD driver. But as delivered one can't install the flap servo in adherence to standard accepted practices. THERE IS JUST TOO MANY INTERFERENCE ISSUES WITH THE STANDARD 10mm x 30mm x 30mm SERVO!
I'm sorry Doc, but since your name is on the design credits I have to ask what was the intended shape (Part Number) of the flap servo. I know we covered this a bit
here. But this just drives me nuts. I hope that the Spada wing has addresses these fit issues.
Now I do have to say that the CAM work looks nice. Assuming there wasn't a lot of hand fitting of the molds.
OK, I'll step off my soap box, rant off.
Sorry about that.
It was good to wake up this morning to find that the epoxy had cured. I hooked up my servo tester and found that the second to last of the smaller IDS servo arms actually gave me close to the amount of surface movement I wanted. With the way I had placed the surface spoon (control horn) I was actually a bit short on throw. With OpenTX and Mike Shellim's templets I can expand the servo motion to get the desired throws.
I know that the Redshift supplied by Aeroic came with Doc's servo trays. With my Redshifts I'm using the the
Servorahmen IDS system. What follows is my attempt to install the flap servo with the Servorahmen system. This is a personal preference issue and nothing against the actuation method used by most manufactures.
The first thing after re-hinging the flaps was to remove the factory installed control horns. Now based on what I learned with my first Redshift I knew that the placement of the control horn was way too close to the ballast tubes and wing box (you can see this with the need to use a serpentine push rod). So I had to move the control horn (spoon)outboard. What limited this was the placement of the flap cover recess. If I was going to cut into the recess flange and not into the bottom skin I could only move the spoon 4mm to 5mm. This makes the installation of a 10mm thick by 30mm x 30mm servo very tight!
The Key concerns were avoiding the ballast tube end, placing the servo fore and aft inside the window provided, push rod alignment, and clearance to remove and install the servo after the IDS was installed.
I found that the best IDS components were the second from the smallest servo arm and a 54mm push rod. This allowed the placement of the servo close to being centered in the window (the servo is forward 1.5mm). With me squinting my eyes it looked like I could get the flap servo installed and still not violate the servo window.
Well. the problem was that one needs to be able to replace the servo. One can't bolt together the assembly and glue it in place. One needs to get at the screws and have clearance to slide the servo out of the control arm splines. To gain the needed clearance I had the thin the ballast end cap by cutting a trough to allow the servo tab to nest into. I also needed to remove all but about 1mm of the inboard window flange. And because of some lead angle issues I had the thin the back side of the rear mounting brace.
All is not perfect. Even with the 10mm servo biased 1.5mm towards the LE the rear of the servo violated the window flange height. It is still below the wing skin, but just barely by 0.15mm. This is why I didn't add any carbon doubles to the servo pocket. I hope I can make a servo cover that is still flat.
So with sacrificing some servo cover flange I think I was able to actually fit a flap servo into the Redshift wing! Now for the hard part doing it again on the other side.
I wonder if this was the intended
servo? But overal length is close to the same as the X10 mini but at half the torque and twice the price. Actually the only thing this servo solved is the cover issue.
