I often judge a man’s true opinion about a product by wether he spends his own resources on a replacement. Well, I was so impressed at the potential that my first Redshift (a used purchase) demonstrated in only its first dozen or so flight that I purchased a second Redshift. My first Redshift was a prototype and built by the owner in a rush, by his own admission. With the first Redshift I learned a lot about how to assemble one. I hope to put this knowledge to good use on my second Redshift.
The only real issue I had with the design of the Redshift, was the short control horns for the V-tail. I think I have come up with a practical work around to this issue.
forum.alofthobbies.com
There is also an issue with the OEM quality for the Redshift Mk I. This production kit has been inspected by the designer and no gross errors are apparent with this kit. Add to this that I think I can add some durability based on my repair of my damaged Redshift #1 and I confident that my 2nd Redshift will be of great value to me. I’ve been told that there is a Redshift Mk II (Spada) in development with a new OEM that addresses this issue and adds some subtle improvements. Right now with this Covid 19 pandemic I have some time to build a new ship. I didn’t want to wait for the Redshift Mk II (Spada) particularly when I think I have a more than adequate fix for the Redshift Mk I.
Unlike what we see in today's trend towards ballast in the wings, I’m staying with the ballast in the fuselage. As the Redshift Mk I has the fuselage cross section to carry a ballast tube I see no advantage to a wing ballast systems. In fact I see wing ballast as being detrimental as it dampens the roll response resulting in more control drag for any given aileron control rate. I’m also getting rid of the square ballast tube. I favor the round tube for the adoption of 19mm Tungsten crankshaft counter weights.
I will be doing away with the glass servo tray as it fails to carry the nose loads into the fuselage hoop structure. In fact is stops in the middle of the ballast loading window, not good for my type of landings!
I will be using mini X-10 for the flap servo (30mm x 30 mm). These have the same gear train as the full size X10. For space reasons the full size 30mm x 35mm servo won’t fit. Much to my surprise the KST X0-8 withstood my crash landing just fine. So I’ll stick with the KST X0-8 plus V2 for the ailerons.
Redshift; Used Purchase
As a result of family issues and that the race season is coming to an end I don’t think I’ll be racing any F3F until 2020. During the 2019 season I was using the very economical (read cheap!) and well dated Strega’s. These did what I hoped they would. That is give me a chance to learn what F3F...
