Some of you might know that I've just acquired my 3rd Redshift. This was the airframe Aeroic used to test the molds looking for issues like negative rake and other fit concerns. As such it was laid up in glass and does NOT represent the end Aeroic product. This airframe was used as a demonstration ship by Aloft. As Aeroic and Aloft no longer field this aircraft it was surplussed to me.
I was ecstatic to get this airframe as it looked ready to fly (I had actually flown this at an ISR) and she came with a great set of 4 X10 mini and 2 KST 215mg servos. These will fit my penchant to use 2 lipos for my radio set. I plan to use her as a light lift F3F racer. I want to stay with the high aspect ratio wing at my current state of F3F development.
Now I need to learn that there is no such thing as a PNP model when it come to my expectations. I was hoping to use this Redshift in the first F3F race of the season on February 20th. Prior to setting up a radio I gave the airframe a close look over. I was happy to see that it had my tail flip mod. I figured that was going to be the rate limiting step. But no I looked at the flap movement and found that the flaps only reflexed up 5°. that is to say the flaps did NOT augment the ailerons in roll. Damn, I though all I had to do was lengthen the servo arm and program my flap curves. But NO I found that all 4 control horns caused surface binding in the upward direction!
This will force me to remove all four control horns. If doing all that work I might as well install IDS to all the wing surfaces. This is a good thing, it just that it means a lot of work and I'm facing the February 20th dead line. Damn another issue, none of the servos can be freed from the servo trays as there is no clearance provided to move the servo away from the bearing. I was forced to force the servo out of the servo tray. Because of the geometry I'm going to have to replace the flap servo trays. As I'm doing all this work I might as well go all in and change the Aileron servos to ones that are 8mm thicK. Luckily the servo trays were glued in with what looks like CA and broke free with little damage to the top skins as they don't look to have been permanently distorted by this. And damn the wiring harness does not expose the servo connector when the servo is taken out of the servo tray. So I'll have to change the wiring harness if I want to change the servo.
So two days after purchasing my PNP F3F racer, the wings are now in the condition of an as received kit.
