Over the last couple of years I had 3 receivers (ACCST) going bad while not being used. In all cases, the receiver had not been used for several months, either because I did not fly the plane/drone or because I sold the airframe. The receiver was working properly when stored. After pulling out of storage, the problem would manifest with very low RSSI despite having the radio close by (from 3' to 10' away). The last instance occured with a S8R. Used it last time 6 months ago, working fine. Couple of days ago I put it into a EDF I am building, and discovered that RSSI was in the low 60's with the radio 10' away. Putting the radio in range check dropped the RSSI to 35 at the same distance. Obviously this RX is not going to fly my EDF. More or less, this is what happened in all other cases.
For the record, I replaced the receiver with an older X6R upgraded with the UNI firmware and it is working fine, which rules out radio problems.
Has anybody experienced similar problems. Again, the receivers that went bad were stored properly. In all cases, the problem manifested as low RSSI. Could it be capacitor degradation over time?
