Turiu „Frsky X10“ siųstuvą su „OpenTx“ programine įranga. SR6Mini imtuvas. Kaip reguliuoti giroskopo funkciją – imtuve ar siųstuve? Ar reikia pakeisti siųstuvo programinę įrangą į ETHOS, ar tinka „OpenTx“? Plokštuma yra delta.
" I have a Frsky X10 transmitter with OpenTx software. SR6Mini receiver.
How to adjust the gyro function - in the receiver or in the transmitter?
Do I need to change the transmitter software to ETHOS, or is OpenTx suitable?
The plane is delta. "
Hi
difficult answer!
I guess it's a newly bought SR6mini. So it will have a firmware version V3.0.... on it. The required new LUA scripts for OpenTx/EdgeTX are not supplied by Frsky (only Ethos)
I would recommend latest firmware version V3.0.3
Possible solutions (other than using ETHOS) are.
1. downgrade the receiver firmware to V1.0.10 (do not use V1.0.11 would already require new scripts) and use LUA scripts V2.04 for OpenTx
While this is working fine there is a small drawback. Firmware V3.0.3 introduced a kind of filter to eliminate the influence of motor vibration. (Has a big affect on my indoor, makes it flyable without erratic movements)
3. Now I have only small radios with OpenTx and small black and white LCDs. So I adapted this Scripts to run also on OpentX and b/w LCDs.
I have not tried them on a Horus (used them only with x9D2019 and x9liteS, Archer plus SR8 and SR6Mini). It's very likely that they run on Horus too (tested on Simulator)
You will find the scripts (see link). Do read the readme file carefully and stick to them.
