stephen66
Situation: Biplane using all 8 channels for flight control. I am short one channel to handle the ignition opto kill switch. Yes, I can use an R10 but want to use what I have--and gain the advantage of redundancy. I think I understand but nothing is ever clear cut with FrSky products...so check my sanity.
Plug R4 S.port/F.port SBUS-In --->> R8Pro SBus-Out
Does the TX simply continue Channel counting UP from the Master? Meaning R8 CHs 1-8 adds R4 running 9-12 ? Can I just "y" out of the switch and run both RX on a single battery? Yes, the battery becomes a single point of failure...but it already is in every other single RX plane. I believe this gives me RF redundncancy but not battery redundancy.
Am I correct? What am I missing?
Oh, is it just me or does the plug for the S.F.port on the Archer seem much less secure than a standard servo plug? If so, is anyone doing anything to increase confidence in that connection? Hot glue? Nails and duct tape?
Stephen
Stephen
