R-XSR Wiring...
TSchwyn
Anyone have the correct wiring to use an R-XSR receiver as the "master" and another R-XSR receiver as slave in another 700 carbon heli?
Thanks for the help!!
Tom
Red to red to +
black to black to -
Slave sbus out to master sbus in
Master sbus out to flight controller sbus in
Check the leaflet that came with the Rx for the pin locations, it may also be screened on the board.
You won't use the 5th wire on the remote, but might on the master for s.port telemetry in.
You will have to bind each seperately. Just repeat the procedure twice. I'd bind slave first and make sure you don't get telemetry back (rxbatt and rssi) then bind master and make sure you do.
If you can't bind without telemetry you'll likely need to upgrade the Rx firmwares or some in the radio. I just went through this getting a G-RX8 master and r-xsr slave setup going.
