R-XSR Fixed wing application.
JiminWA
New member
I had seen reference to this Rx being used in a fixed wing aircraft. All I have found is drone app. Does this have to be used with a FC board or is there a hub or other means of interfacing servos? The hub on your site say Futaba compatible only.
JiminWA
New member
Okay, I was hoping I missed something. By the time you add the Decoder or the Bus the weight exceeds using a different option. I am trying to optimize total avionics package. Already over 40 grams with complete telemetry. Is GPS restricted in accuracy and real time based on civilian use. I may be able to cut weight there if GPS is real time and would replace pitot static component for airspeed. Working on A6 project I spoke to you about. Testing package in other aircraft right now. Thx
JiminWA
New member
Also trying to adapt board for ASS-70 to use 2 static ports 1 in the inlet and 1 in thrust tube to measure EPR or fan efficiency. I will have to make my own ports.
