HornPlayer
I recently inherited a QX7S ACCESS transmitter and decided to go with it as my early QX7 was such a good reliable TX.
I quickly discovered that the 18650 cells combined with USB charging is full of pitfalls for old players like me. First of all I decided to check it out with 2 cells from another radio - it turned out they were getting a bit tired.
Lesson No 1: Do not assume that, just because a battery pack will switch the radio on and run it, that it has enough grunt to switch the radio off properly. The radio appeared to have turned off, the blue LED had gone out, but the audio circuit remained on with a small residual current draw and a low buzz/hum of white noise. Brand new batteries fixed the problem - as did a 2 cell lipo RX pack.
Lesson No 2: With new 18650 batteries installed and charged using USB via internal charging circuit cuts off at 8.3V - when the green charging light switches off. The radio will not start up at any voltage over 8.0V. I had to externally bleed off 400mA to get them back into usable range. It appears that the only reference to battery voltage in FrSky's sparse instructions is correct to the nearest mA of 8.0V - 6.0V. I haven't tested out what happens when voltage bottoms out at 5.999V and have no intention of chancing it and have set alarms at 6.5V
Strangely enough I have found no direct reference to these problems anywhere on-line although there are a few references to switch-on failures.
