I recently acquired a used QX7 Legacy TX which operates on 6.5 - 15 volts. I am currently using a 2 cell lippo battery that also was included with the TX. Can I plug the battery's balance lead directly to the TX JST 'as is' or does that connection need to be reduced to a two wire?
The TX also has a three pin charging port, like a servo connector, on the right bottom bend of the case. A wiring lead that fits the external charging port also came with the TX. It has a 3 pin servo type plug modified with a keyway in the top and a 'clip' of sorts on the bottom. It is wired L to R .. red -yellow -black with a 3 wire JST on the other. Am I to assume I can use this lead and my lippo charger to charge without any issues?
I have Aloft's manual for the QX7 which I am studying but haven't found the answers.
Thanks for your help in clarifying this for me.
