I am trying to set up a progressive setup for my 6 servo plus motor sailplane. What I mean is, for the first 50% of butterfly deploy only the flaps move. Then on the second 50% of stick movement the ailerons start to raise. I already know this doesn’t work using the butterfly mix on my X18S transmitter. I have tried outside of the butterfly mix to setup such an aileron,mix using the throttle that sends the ailerons up on the final 50% of stick movement. No joy. I turned off the butterfly mix to try to create the set of mixes using the throttle stick to no avail. Being new to the radio probably doesn’t help either. Suggestions would be appreciated. Thanks in advance, Bob
