Programming for an EDF
JPHen
Ran into a problem programming my 200 amp 5-12s opto esc on an EDF. Radio is Spektrum.
Initial startup was forward/reverse and went straight to throttle - looks like a setup for crawlers. Edited setting for 6 on timing, 4 poles and forward only. Now esc will only chime when plugged in but doesn’t arm. Not sure what to do next.
@Jarron Any help?
We are working on a friendly set of instructions, but it is not very far along just yet.
It does sound like you had the setup for a crawler by default. Do be careful as the crawler settings can put some heat into a motor.
Software version 14.
Here’s my setup.
