Problems binding S8R
Guess I should have come here first! LOL.
Its a pain but I sure am glad that this forum is here and that Frsky keeps updating the firmware.
As long as we are talking receivers, Do you feel that the X8R is still a good receiver for Electrics and Ducted fans? I updated the many I have and have never had an issue with them in the past.
Nothing wrong with them. :) Some of the newer radios are said to have longer range, but I'm not a range pusher, so no issues for me. :)
Hi,
I have just purchased a S8R and cannot get it to bind with my taranis qx7. Reading the posts I am trying to flash S8R_ACCST_V2.0.1_FCC.frk as my other receivers and transmitter have v2.0.1. The problem is that the file is not on the frsky website!!! do you know where I can download it? Thanks in advance.
I meant he shouldn't leave his equipment on 2.0.1. But yes there is no 2.1.0 for S receivers yet either...
I’m using a Taranis X9D Plus 2019 SE running 2.3.14-otx and I can bind with an old S8R (not recently updated firmware), but I also have two newer receivers that I’ve never been able to bind. Both updated to 2.1.0 firmware. When trying to bind both the red and the green light lights up and when I power it up again, they both blink red. I’ve tried to flash both EU and FCC versions and neither works.
I think it is unlikely that I have received two defect receivers, but I’m quite lost and would appreciate some help.
Best to post up in this dedicated thread, should get some good help there.
If your radio will bind to an old S8R, it is not running the new 2,1,X RF firmware. You will need to update the radios RF. Then you will be able to bind to your X8Rs.
PS. You will have to update the S8R too...
Thank you, this really solved it for me! I managed to update the two new receivers from the PC. This did not work for the receiver that I was previously able to bind to, but I was able to update it connecting to the radio with a modified cable.
The only (?) challenge left is the XM+ receiver in my BetaFPV hx115 that I understand might need soldering to be able to update.
S8R just purchased (ordered 17 October 2021) will not bind. I have two other older S8R's that I currently fly and they work fine. Transmitter is X7S with OpenTX version 2.2.0 (63baa76c) dated 2017-09-15.
X7S transmitter is setup with internal RF at D16 mode with channel range of 1-16. Selecting Bind causes the Bind parameter to flash and speaker chirps.
Holding the F/S button on the S8R during power up gives a steady green and red LED. No change to LEDs when F/S button is released. Never see red LED flashing which would indicate binding.
Cycling power to both transmitter and receiver results in green LED off and red LED flashing on the receiver which indicates signal lost.
If I leave the X7S transmitter off and hold the F/S button on the S8R during power up I get exactly the same response on the S8R - steady green and red LED with no change when F/S button is released.
Marti M. Sarigul-Klijn
The new receivers all have V2 firmware on them. You will need to downgrade the new receiver or update the older receivers and radio to the New version.
