I’m having problems binding a S8R to my Taranis X9D+. The X9D+ is running vers:2.2.2RC5 (2296cd5f) dated 2018-07-17. The transmitter binds normally to X8R receivers.
I flashed firmware FW-SxR-v2.0.17 (S8R_ACCST_V2.0.1_FCC.frk) to the S8R. I also downloaded the newest copy of SD card contents containing an SxR file with SxR.lua, Sxr_Calibrate.lua, and SxR_Calibrate.luac subfiles.
I set the Taranis to D 16 mode and ch 1-16 for the channel range. When I try to bind, the green and red lights are steady on. After exiting bind mode, when powering the S8R on, the green and red are on together; then the green goes off and the blue flashes and the red flashes for a few seconds; then the blue goes off and the red continues flashing. It isn't bound.
I’m very frustrated, PLEASE HELP!
