problems binding access flex on r9mm-ota receivers
Martin
i am having problems binding access flex on r9mm-ota receivers with the x20s tx. they will bind sort of but nothing more. i think in then binding process it registers and then fails. so i am having to use the fcc version. i would like to use the flex firmware on my new $465 radio.. i anyone else having thins problem?
I would make sure to update internal ISRM module of your radio to latest FW . Make sure you are running the latest fw on rx . Make sure if you are running flex then you flash it with the flex fw not fcc .
Allen
thank you. hey i'm also in oklahoma. outside stuart in the sticks...lol. how ya'll i rush springs? going to see the eclipse?
