CrashGuard
I've been using Frsky X18s for around 4 years and was curious about the Archer Plus SR6 Mini that was added into the X18's update. I want to go small (indoor micro) or low power using the common brushed 8520 motor. So how should the power distribution be implemented? The two motor pads are large enough to carry 5 amps each as stated, but where does it get a total of 10+ amps from? The tiny pad next to channel 6? (Really) I tested a motor using a fully charged Lithium Ion @ 3.7 v and a standard toy prop and got 4.6 amps draw.
That tiny motor screams with only 3.7 volts and is only rated to 5 volts. I could go 2S Lipo but that would be too much. Perhaps, that is what min and max throttle is for. I don't know. Any ideas would help. I thought of using the 14 amp SBEC Neutron on 5 volts, but I'm not sure it will play nice with 2S because it suggest having 6 volts above the output voltage. Hum...
Also, it would be nice to know if the motor outputs are PWM or DC FET regulated.
